Finally made it out to the shop today, got the tranny and exhuast pulled from the 2056, its going down south next weekend. Took the white car off the lift and moved it out of the way.
Took the new car for a
around back roads by the house, 1.8 with a single carb....what a dog.
....quite slow compared to the 2056....but once you get up to speed its all good
Then drove it into the shop and put it up on the lift. Needs the clutch tube welded. I'm going to drop the engine, change out the leaky tranny for a rebuilt one I have, do some clean up, install the missing piece of engine tin, replace the plastic fuel lines through the tunnel, and install a new ball joint......then it should be drivable.
Shop rearranged, new car on lift......the others waiting
Click to view attachmentJeff
