JawjaPorsche
Mar 8 2012, 04:33 PM
I am glad I am not the only one who uses a piece of cardboard to catch those pesky leaks!
QUOTE(Bob L. @ Mar 8 2012, 01:16 PM)
QUOTE(6freak @ Mar 8 2012, 10:00 AM)
Click to view attachmentfits good lots of room to move around
All right, now You're just showing off!
6freak
Mar 8 2012, 10:28 PM
QUOTE(JawjaPorsche @ Mar 8 2012, 02:33 PM)
now i can work on fix n those leaks ...lots of oil and crime under there..time to get on it
TravisNeff
Mar 9 2012, 11:50 AM
After 5 days of gas tank de-rusting through electrolysis the tank looks clean, extra time was needed for all the rust and removing the coating that failed.
Swish around a bunch of metal ready in the tank & rinse
Then onto the caswell 2 part epoxy tank sealer
ClayPerrine
Mar 9 2012, 12:12 PM
Drove Betty's 914 to work today. Got to replace the CHT on it tomorrow.
(Yes, she lets me drive it once in a while........)
euro911
Mar 9 2012, 10:14 PM
Removed some peeling tint film and adhesive residue from the rear window (what a pain in the ass that was)
... and Installed the rest of interior stuff. It's not great, but a lot better than it was
Click to view attachmentRemoved the original rear bumper from my wife's car, polished it up, installed both front and rear on my car
Click to view attachmentClick to view attachmentAfter all that, I actually like the look of the black bumpers better
... oh well
Finished up the last of the under-car items and we put it back on the ground. Carbs received new throttle return springs and were re-jetted. Richard installed the carbs along with the CSP linkage. Also installed the rebuilt dizzy and new plug wires. Brad Penn break-in oil and fresh gas are in, should be ready to fire up in a day or so
effutuo101
Mar 10 2012, 07:28 AM
Built a thread on my build...
Daiberl
Mar 10 2012, 10:36 AM
Dropped the engine to fix an oil leak, hope to have it done within the next 2 weeks so that I can put everything back together and drive the car.
sixnotfour
Mar 10 2012, 12:19 PM
Drove it to XXX Porsche breakfast.
mtn flyr
Mar 10 2012, 12:20 PM
Put air in the tires, checked the oil and drove
in case anybody is wondering a 2270 really brings these things to life!
euro911
Mar 10 2012, 12:24 PM
It's FIX-IT DAY
1. Fixed a broken armrest on my favourite [but badly deteriorating] garage chair (what a CSOB)
Click to view attachment2. I leaned over to grab something out of the glove box and my home brew cup holder collapsed
Used larger diameter dowels this time + added two more in the middle. Secured them with screws instead of skinny little finish nails
Click to view attachment... and 3. Started repairing my dual-outlet valance
mrholland2
Mar 10 2012, 04:33 PM
Charged the battery
Re installed the battery
Drove it a bunch (what fun)
Parked it
Disconnected the battery so it wouldn't drain.
Mike Bellis
Mar 10 2012, 05:00 PM
I removed my transaxle, adapter plate, flywheel and clutch. Sorry no pics.
P.S. I touched up the paint on the firewall...
'73-914kid
Mar 10 2012, 05:23 PM
It was a rather busy day on the 914...
-Installed a wilwood brake proportioning valve (bled brakes about 3 times)
-Set rear caliper vent clearance.
-Cleaned/restored windshield wiper hardware (seals and such needed to be cleaned and polished
-Cleaned my old rubber rear trunk pad from the parts car. I was amazed I still actually had it. I don't ever remember pulling it from the parts car....
-Installed new targa latch cups in the rear trunk after melting holes in it for the battery cables to run through.
-Replaced tail light bulbs that were desperately in need of replacement, in preparation for the new set of tail light lenses.
That's it for today..
914itis
Mar 10 2012, 05:30 PM
Valve adjustment , installed cv,s. ( pita with the motor and trani on the car )
billh1963
Mar 10 2012, 05:33 PM
Took the green 914 to Bob Woodward to get the clutch tube repaired
Pulled the rear suspension off the orange parts car
Racing916
Mar 10 2012, 06:50 PM
Rebuilt Tranny from (Dr. Evil) Installed.
Communicator Installed and changed the oil.
Ready to eat up some 911's as soon as the snow melts
mr914
Mar 10 2012, 07:14 PM
Flipped mine on its back like a turtle....
To fit floor pans and fix some of the other rust holes.
I will be holding the pans in with Chelecos (aviation, removable fasteners) untill I can get it on the bench to straighten before welding.
Looks like the easy way to fit a sittening kit.
Haudiosolutions
Mar 10 2012, 07:24 PM
Bled my brakes again, Fitted new wheel adaptors and rear wheels, Need to cut more clearance for the front hubs. Changed the oil, replaced my accelerator cable (because I had a new one laying around and didn't know the condition of the old one.) Cut my dash panel to accept the new head unit which is on the way with my handy Dremel I just got and worked on refreshing the top and getting ready to install a new head liner. Busy day but not as productive as I had hoped.
sofi2t81
Mar 10 2012, 08:24 PM
I finished my dash face recover. (see separate thread) replaced the coil, dizzy finger and cap (no idea if this ia the right term) repainted some dinks.
Found out that the finger was the wrong one.
Put the old one in and had a nice drive.
Peter
TravisNeff
Mar 10 2012, 08:30 PM
Didya play blood on the saddle from the jukebox? Mandatory activity when you hit the xxx in Issaquah....
QUOTE(sixnotfour @ Mar 10 2012, 11:19 AM)
hot_shoe914
Mar 10 2012, 09:08 PM
Took it down to the AX and
the
out of it.
ClayPerrine
Mar 10 2012, 10:40 PM
Put in the new cht on Betty's car, plus a cap, rotor, plugs and wires.
AndyB
Mar 11 2012, 06:19 AM
Spent more money on her.
JRust
Mar 11 2012, 12:23 PM
Finished installing my interior. Put my freshly painted front LE Valance on. Put on the front bumper. Hooked up my tailights, Put the top on & drove it in the rain to get it detailed after many months in the shop & layers of dust. I know not the best weather to be getting it all cleaned up. Making a trip & it will clean so much better after getting waxed up
MrHyde
Mar 11 2012, 06:27 PM
Got the rear trunk pan about 95% welded in
iamchappy
Mar 11 2012, 06:34 PM
Took the RA-1's off and put the all season ContiExtremeContacts on, will save the Ra-1's for summer. Weather predictions are that we will see temps in the 70's this week and i am going to drive the turbo 914 again. Woohoo....
poorsche914
Mar 11 2012, 06:43 PM
Met up with another 914, a couple of 911s, a 356 and a Miata and drove the Dragon
GaroldShaffer
Mar 11 2012, 07:04 PM
Picked up a Rotisserie for the project car.
wndsnd
Mar 11 2012, 07:14 PM
Cut out rust, welded and grind.
PeeGreen 914
Mar 11 2012, 07:21 PM
Primed the front suspension consol. Time to break out the airbrush.
Eric_Shea
Mar 11 2012, 07:30 PM
hot_shoe914
Mar 11 2012, 07:57 PM
Took it down to the AX and the out of it.
Same thing I did yesterday.
poorsche914
Mar 11 2012, 08:12 PM
How'd you do, Shoe? Which 914 did you drive - Delilah?
shuie
Mar 11 2012, 08:42 PM
installed a JWest trunk hinge kit and finished grinding, drilling for plug welds, cleaning, prepping, and primering for my rear firewall replacement surgery. The JWest kit is really first class. The only pics I took..
KaptKaos
Mar 11 2012, 11:36 PM
Installed new SVDA dizzy and vacuum lines. Running better, but still needs tuning on the carbs. Scheduled for Tuesday.
Eric_Shea
Mar 13 2012, 10:02 AM
Installed the tank... just for fun of course. I get to take it back out tonight! Weee...
Other than that the front trunk is "done".
914itis
Mar 13 2012, 10:06 AM
Got the motor running again, installed center console gauges and seat tracks
Phoenix-MN
QUOTE(iamchappy @ Mar 11 2012, 04:34 PM)
See post #14
DRPHIL914
Mar 13 2012, 11:37 AM
I put in new door panals from Morph at 914 A&P!! here is the driver's door-
came yesterday , installed last night!
Drove the car to work today!
JawjaPorsche
Mar 13 2012, 11:39 AM
Replaced a fog light blub. I wished I had smaller hands!
euro911
Mar 13 2012, 05:12 PM
Oooh, nice top, Eric
At first glance, thought it was from a 911 Targa (but then again, I also need a new monitor)
Door panels are nice, Phil (911-ish)
struckn
Mar 13 2012, 07:42 PM
Cleaned it's room (garage) and put it's toys away (tools). Turned the light out an said good night.
effutuo101
Mar 13 2012, 09:45 PM
Sanded the targa top. Just on small space to go.
struckn
Mar 14 2012, 02:49 PM
Went TOPLESS....72 Degrees perfect day.........NO! I'm the boob driving not the other kind of topless.....geesh.
DRPHIL914
Mar 14 2012, 04:41 PM
Put my WAS top on because rain was in the forecast early, and clearlater. Ended up 80the today, took the top off for a great drive
nickp997
Mar 14 2012, 05:51 PM
today i pulled seals out of front and rear trunk and found more rust. removed rocker panels..more rust. getting her ready to begin stripping for new paint
euro911
Mar 14 2012, 07:45 PM
Went to start the 'BB' this morning and the right carb was leaking. Pulled the top to check the float, needle & seat - noticed that the choke ports need to be plugged. Pulled the top from the other carb and called European Motor Works. George will have 4 plugs machined and ready to pick up by high noon tomorrow
Click to view attachment Had 2 doctor appointments (getting old isn't all it's cracked up to be)
Then basted and painted a steering wheel adapter for my 'NONO' wheel (it's Not a 'MOMO') ...
Click to view attachment ...will pick up new hardware for it tomorrow
Elliot Cannon
Mar 14 2012, 08:36 PM
Adjusted the valves today. Haven't done it in a long time and it's still a pain in the ass. While it's on the lift, I discovered the front wheel bearings need adjusted, so that will have to wait till tomorrow. I discovered 0 valve lash on ALL valves today. I couldn't get even the thinnest feeler gauge to slide in. That can be done with my engine but I can't tell if it it's beyond 0 lash or not so I made them all about .004. Started it up and sounds good. The best part is no oil leaks. (So Far). Lookin' forward to the ride to Arizona soon.
Cheers, Elliot
914itis
Mar 14 2012, 10:17 PM
Changed motor oil with brad pen 20/50 ena bled the brakes using the hf easy bleed
euro911
Mar 14 2012, 11:35 PM
QUOTE(Elliot Cannon @ Mar 14 2012, 06:36 PM)
Cheers, Elliot
Are you sure you don't have chrome moly push rods? They would be adjusted at zero lash.
If they're the stock aluminum rods,
.004 should be is OK if the temperatures don't get too high.
I recently read a couple of good articles on push rods:
Engine Builder site and
ShopTalkForums
