QUOTE(lonewolfe @ Dec 25 2014, 12:22 AM)
Awesome! I have a 1970 Tintop Westy waiting for a fresh engine to go in!
Cool - what's the displacement? I had an 1835 in my old '67 (which was built by Randy [Automeister] 40 years ago). It kicked ass and I put 175k on it
Post some pix of your project.
Eileen's previous owner didn't provide me with much info, so I was happy to learn how good of shape she was actually in, especially that the compression #s were really good - don't need to think about a Subi conversion quite yet.
I had purchased most of the parts and planned on doing the work myself, but there were just too many other chores on the to-do list and the guys at Automeister are really good folks.
New stuff that went in: Go-Westy 1.5" lift spring kit, tie rod ends and rack boots, upper & lower ball joints, all bushings, rear brake cylinders and shoes, and front pads. 1 CV joint needed replaced and they replaced all 4 axle boots (were starting to crack). All the clutch components and the other 3 CV joints looked like they were recently replaced, but she did need a new clutch slave cylinder.
When they pulled the trans to replace the engine rear main seal they replaced the input shaft seal on trans, also installed new injector seals and all the fuel, evap and vacuum lines. Then a performance tune-up finished up the job. I have to say, she's running pretty good for a 30-year-old tank
