Installed the welmeister deep sump (tuna can).
Removed & cleaned oil filter while I was down there.
Unscrew oil filter and oil cooler sandwich adapter unscrewed with it.
No big deal. Screw it back on, clean oil filter and reinstall.
Strain & Filter slightly used ~4 quarts of Brad Penn and put back in engine.
Crank engine & it starts immediately, get distracted fussing with carb return springs getting in my way. (engine putting like a tractor).
Rev it once and see that I have NO OIL Pressure.
Look down and see that I am standing in a puddle of oil.
Fast forward ~2 hours after I drop car from jackstands, clean up my mess and put car back up on stands.
Pinched the sandwich adapter plate gasket when reinstalling.
Fixed sandwich adapter plate gasket,
TORQUE adapter plate to 9.5 ft-lbs, Put in 3 NEW quarts of Brad penn and try again.
THIS TIME I crank engine WITHOUT STARTING it and I can get my oil pressure
up to 60 PSI with just the starter See that it is 11 PM and cant start the car.
