euro911
Jun 22 2016, 11:58 PM
Well, the wheel repair shop that I took my bent wheel to up in LA said they couldn't fix it
... so I called around and found a shop in Santa Ana that said they can typically repair what others can't - so that's where I took it yesterday afternoon. When Jeff spun it on the spindle, he thought they could only guarantee that it could get to about 85 ~ 90%. He called another guy to look at it and he said maybe 90 ~ 95%
Jeff called this AM and said it's ready. When I got there, he hoisted it up on the spindle again, and damned if they didn't get it almost perfectly true. They claimed it's 98 ~ 99%, and I'm perfectly happy with that
They cleaned up the minor curb rash too
Click to view attachmentClick to view attachmentIt did cost a little more than I was expecting, but since these wheels aren't too abundant these days, I think it was worth it
Click to view attachmentI highly recommend these folks
Now it's my turn - need to clean all of them up a bit, and maybe even have them powder-coated ?
Frankvw
Jun 23 2016, 12:48 AM
I posted my introduction yesterday (first 914) on the Garage forum and this morning I added my VIN nr to the VIN database
http://www.914world.com/bbs2/index.php?showtopic=288042Thanks for the welcome.
euro911
Jun 23 2016, 01:33 AM
51 posts in your first two days?
Frankvw
Jun 23 2016, 01:42 AM
No....51 since I joined in April. But I did my real introduction after I bought a 914. :-)
QUOTE(euro911 @ Jun 23 2016, 01:33 AM)
ssuperflyoldguy
Jun 23 2016, 08:31 AM
Didn't quite get to it, receiving garage space has been filled temporarily
mbseto
Jun 23 2016, 10:50 AM
Mueller
Jun 23 2016, 11:11 AM
No actual work....
I bought the complete stainless fuel line kit from Rotary'14, looking forward to getting those parts and getting them installed.
Got some new rims, the wife hates them and wants me to keep the phonedials.....we'll see.
euro911
Jun 23 2016, 01:44 PM
Apparently women like phone dials ... I see it all the time
Last930
Jun 23 2016, 02:41 PM
Mine's in the shop getting painted - the car I mean, not my wife! I can't wait to get it back - should be in primer tomorrow!!
Rockaria
Jun 24 2016, 11:22 AM
Got tired waiting for the factory to do new paint jobs, so I did two of my 914s myself.
Click to view attachmentNow my collection looks better.
Click to view attachmentOh I washed and drove my "real" one as well.
euro911
Jun 24 2016, 12:14 PM
I had to paint one black to match the 'BB' a few years ago.
There was a guy (Bill) that used to attend the G&R Swap Meet, that custom-painted them in any factory color one wanted. He also installed different wheels on them. I bought a white one from him for my wife
wndsnd
Jun 24 2016, 03:49 PM
I blew up rear brake line and/or regulator. Not sure yet but brake fluid is all over the firewall and the pedal went to floor.
Good news was the Brake Emergency light worked and started flashing...
cary
Jun 24 2016, 09:22 PM
Took a long lunch and changed out the worn out left output shaft seal on my DD.
Expected to see a wear pattern on the shaft. None.
The seal actually is worn out. Didn't measure it. You could see it with the naked eye.
Click to view attachmentClick to view attachmentPlus my new tuna can needed a little less than a 1/4 turn to snug it up. Had a little drip .....................
iankarr
Jun 24 2016, 10:28 PM
Finally getting around to post this vid from Father's day. Me teaching my son to drive stick. Can't think of a better 914/father's day activity.
https://vimeo.com/ikacollective/review/172192595/9d46c41c7c
Dutchdriver
Jun 25 2016, 06:07 AM
Working on stuck rear brake. Bled the system, removed parkingbrake, pads etc.
Pushed piston back, which went well. First trying if this will fix things. If it doesnt I will rebuild caliper.
North Coast Jim
Jun 25 2016, 08:25 AM
QUOTE(mrbubblehead @ Dec 17 2011, 10:07 PM)
i just wanted to start a thread to see what you guys do day to day on your cars.
i'll start,
about a month ago, i pulled my engine and trans to put in a new clutch. had the flywheel lightened and resurfaced. but what i didnt know is that i had to shim the little ball that the clutch arm rides on, after a resurfacing. so guess what i did today?
yup, pulled the trans and put an extra washer under the ball. you have to goop up both washers to get it to seal because the threaded hole goes all the way thru to the inside of the trans. i also replaced the plastic cup that the ball rides in. the throwout bearing and its little plastic blocks were fine so i buttoned every thing back up. 5 hours total. i think this has been the cheapest repair yet on my car. $2.75 for the little plastic cup.
what did you do to your 914 today?
Picked up the motor today. Just about ready to button up and put back in the car. We should be driving it in 30-45 days or so. Getting excited.
sb914
Jun 25 2016, 12:23 PM
euro911
Jun 26 2016, 09:34 PM
QUOTE(cuddyk @ Jun 24 2016, 09:28 PM)
https://vimeo.com/ikacollective/review/172192595/9d46c41c7cCool ...
Larmo63
Jun 26 2016, 10:04 PM
I scored another set of RARE factory 914 ski racks….just in time for July…….!
2mAn
Jun 27 2016, 09:26 AM
Finally got my hands dirty on a 914. Pulled a motor/ trans for Mr Bowlsby. Start to finish in about 5 hours in 90*+ weather and taking my time to make sure nothing broke. No pics though
7TPorsh
Jun 27 2016, 09:56 AM
Car started running weird. Runs great cold then after about 15 minutes it starts misfiring and spitting up the carb on #4 cyclinder.
So dropped by my friends shop (local friendly Porsche guy) to run a compression test. Unfortunately it was being used on the Cobra. He's got a broken piston but mine is still a puzzle to be solved.
...painting on the wall is a 914. He's got a Boxster engine sitting around that he wants to put in my car...I keep telling him it won't fit...gotta get the 4 running smooth again.
JFG
Jun 27 2016, 01:07 PM
The driver side rear fender is too dimpled to flat with just spray primer so I stripped it back and put a thin skim of filler on it. Then rubbed most of it back off! The drivers door was painted as a tester but then my son opened the garage door and this caused a wind gust which threw up a dust cloud and stuck to the door.
Will rub down and repaint when I'm happy with the rear wing
Part of my 914 rubber order arrived today and hopefully the rest will arrive tomorrow.
euro911
Jun 27 2016, 02:09 PM
QUOTE(7TPorsh @ Jun 27 2016, 08:56 AM)
Gary, when did you paint (or plate or coat) your engine lid grille? I never noticed it before
Obviously, I also think the contrast looks good on dark bodied cars
SKL1
Jun 27 2016, 04:46 PM
Click to view attachment This should solve rear brake issues and a persistent leak in the fittings!!
Thanks Eric!!!
Now just gonna wait for it to cool down a little- and get the lift installed next week- that should make it a LOT easier job!!
euro911
Jun 27 2016, 05:41 PM
QUOTE(SKL1 @ Jun 27 2016, 03:46 PM)
Thanks Eric!!!
Yeah, crazy hot, eh?
Some friends of mine who recently moved to Buckeye are back out here in So Cal until the weather cools off
tygaboy
Jun 27 2016, 06:40 PM
Worked on fabbing up the piece to close the hell hole on the '75 LS3 project. Gotta love the shrinker: no more pie cuts that have to be welded!
Larmo63
Jun 27 2016, 08:09 PM
I have a theory on Porsche shops/mechanics; they are either affordable=slow and totally unorganized, or good service=really, really expensive.
Plus, finding a person who will even work on a 914 is a trick in and of itself.
Front axle is getting close to being done on my car. I can do this myself, but I traded out some labor.
Larmo63
Jun 27 2016, 08:11 PM
Eight cars in here, and they are ALL in different states of disrepair.
It drives me crazy, I'm a bit too pedantic and Teutonic to be able to cope with the madness going on here.
cary
Jun 28 2016, 07:29 AM
QUOTE(Larmo63 @ Jun 26 2016, 09:04 PM)
Palmer summer chairlift at Timberline on Mt. Hood. Good to go ........
Steve
Jun 28 2016, 08:56 AM
I got a set of Mohn ski racks at the Phoenix show. Lets plan a 914 ski trip!!
7TPorsh
Jun 28 2016, 11:32 AM
QUOTE(euro911 @ Jun 27 2016, 01:09 PM)
Hey Mark, I didn't plate at all. It's actually flat black...a little faded so no reflrction at all.
I kinda like the polished idea....
Mueller
Jun 28 2016, 03:41 PM
Worked on engine, 1 exhaust stud per cylinder is broken, this should be fun!
orthobiz
Jun 28 2016, 09:06 PM
Menmojo
Jun 29 2016, 04:43 PM
Pulled the trans and took it apart for a rebuild
. New dog teeth, synchros and sliders. It's a mess right now.
Should be back in action this weekend.
Menmojo
Jun 29 2016, 04:45 PM
kid914
Jun 29 2016, 06:58 PM
QUOTE(sb914 @ Jun 25 2016, 02:23 PM)
Sweet CF dash cap.
AZBanks
Jun 30 2016, 02:00 AM
I bought one. It is my third 914. My first was in high school. I wish I had taken pictures almost as much as I wish I had it back.
My second was a project. The PO had done a masterful job covering a little metal and a lot of rust with fiberglass. I was glad to get rid of it.
This one is UGLY but it has very little rust. It has spent it's life in California, Nevada, and Arizona. It is another project but it is a good starting point. The worst part is it needs a little body repair on the passenger side fenders.
JawjaPorsche
Jun 30 2016, 11:33 AM
Did a tune-up on my 1.7. Replaced plug wires with Fyrebriad wires. Wires provides thermal insulation at operating temperature of 850 degrees! I hope it never gets that hot. I like how they dress up and the engine and the wires are not laying on the engine.
Wyvern
Jul 1 2016, 03:57 PM
Replaced the Throttle Position Sensor board ...
Gotta say a big improvement
cary
Jul 2 2016, 12:18 PM
Last night ................
Took the wife and did the August SCCA Friday night TSD rally. Come to find out these are trap style rallies and a little over our pay grade for ones first TSD rally. LOL.
Only had to call the Rallymaster once. LOL.Blew by the first check point without stopping, but scored a 37.
It went downhill from there. Final score 937. But we weren't the worst. High score 1238.
Winning score 18.
Absolutely bitch'n roads. Had a ball.
Hint : Read the rule book about 3 times and it would make your first rally a little easier.
Us not, cold turkey.
Click to view attachmentTonight, driving to Ridgefield for dinner.
Looks like the tuna can and output shaft leaks are fixed.
ClayPerrine
Jul 2 2016, 04:21 PM
Last weekend I replaced the whole brake system on Betty's 914 with freshly rebuilt PMB calipers and pads. Grabbed the 17mm master cylinder off the shelf instead of the 19mm. The brakes work fine, but she hates the length of the pedal travel. Putting the 19mm on was supposed to be tomorrow's task. Maybe I can get her to do the replacement, and I can be the helper.
Today I bled all over my new 4.0L engine.
But at least I have started assembling it.
wndsnd
Jul 2 2016, 06:44 PM
500 mile oil change. So far, so good. Nice and clear. Magnet looked clean.
Maltese Falcon
Jul 2 2016, 10:31 PM
Bracketing for the Sheridan front clip
Maltese Falcon
Jul 2 2016, 10:46 PM
Lots of useable sheet metal, scalloped and shaped from the once in place narrow fenders, add a bracket=a little triangulation for the dzus mount platforms. Anyone see a spooky face in the inner fender area ¿
Shadowfax
Jul 3 2016, 06:56 AM
Installed some Hella H4s and a passenger side door mirror.
DRPHIL914
Jul 3 2016, 07:00 AM
Nothing- just waiting for CFR rust repair to be completed, so I put new sway bar drop links on the Audi TT, and listed it for sale
VegasRacer
Jul 3 2016, 10:45 PM
I went to Cars & Coffee and found something I had never seen in person before.
euro911
Jul 4 2016, 12:25 AM
QUOTE(VegasRacer @ Jul 3 2016, 09:45 PM)
Did you display a noble gesture when you saw it? ...
StratPlayer
Jul 4 2016, 07:38 AM
Getting a couple of new items installed this week.. New tangerine racing shift kit, and a new 123 distributor without trigger points.. PMB is doing the installing.
Maltese Falcon
Jul 4 2016, 01:24 PM
QUOTE(euro911 @ Jul 3 2016, 11:25 PM)
Ford Duratec powerplant/ v6 24v. Workhorse of an engine...been around since the mid 90's
Today these variants have gone from 2.5L up to 3.7L (plus big bore kits), also the foundation for the Ecoboost engine (Ford gt, LeMans 2016) podium
I have several customers using MSDS headers , vortec supercharger on 3L
with 5 speed/ quaiffe lsd...stuffed on a Ford contour. 400+ hp on 10 psi boost. Noble gt made a good engine choice
Marty
