Jun 24 2014, 07:49 PM
Even got a big
from a lovely lady in a Mercedes convertible on my way home from work ...
Chris Pincetich
Jun 25 2014, 11:14 AM
I removed the "winter tires/wheels" and put the American Racing alloy wheels with Dunlop "summer performance" tires back on. Lower, grippier, and fun!
195/65 vs. 205/50.
The 4 VW rims w slightly used Kuhmo tires will soon be posted in the Classifieds for sale. Cheap.
reharvey
Jun 26 2014, 06:41 AM
Rebuilt these 914-6 struts for the 5 bolt conversion on my black 73.
AfricanHijinx
Jun 26 2014, 08:10 AM
I got the teener to run again. Fuel pump wasn't getting any power I couldn't figure it out so I just ran a new line to the pump.
Alphaogre
Jun 26 2014, 09:48 AM
I drove mine today!
2 years in the making. Still have some odds and ends to tie up, such as the tac, speedo and fuel gauge not working....but its on the road and running finally!
Jun 26 2014, 06:06 PM
nsr-jamie
Jun 26 2014, 09:39 PM
This arrived at my home a few days ago....hope to get it installed this weekend...want to thank Racer Chris !! its truly a work of art !!
jrrhdmust
Jun 27 2014, 08:38 AM
I got the rotors and bearing installed. I need to run the new brake lines. (Before and after)
7TPorsh
Jun 27 2014, 09:53 AM
QUOTE(jrrhdmust @ Jun 27 2014, 07:38 AM)
good job. that first pic looks like something from the Titanic.
flipb
Jun 27 2014, 11:39 AM
Drove it to work this morning! On the way home, I'm dropping it at the shop for 1,000 mile checkup since the 2056 build. Oil change, valve adjust, plus new tires, and brake MC check/reset warning light.
t collins
Jun 27 2014, 01:08 PM
Installed new sail trim, balanced carbs and
first shake down run around the block.
Mblizzard
Jun 27 2014, 02:40 PM
QUOTE(7TPorsh @ Jun 27 2014, 07:53 AM)
Added a sway bar also?
Mblizzard
Jun 27 2014, 02:42 PM
QUOTE(t collins @ Jun 27 2014, 11:08 AM)
What adhesive did you use. I am getting ready to redo mine with the 914 Rubber German material. The adhesive I used before did not hold that well.
t collins
Jun 27 2014, 04:31 PM
QUOTE(Mblizzard @ Jun 27 2014, 01:42 PM)
I got a qt. from my local upholstery shop, unfortunately, there's not a label on the can. If you don't have any luck let me know and I'll ask him for the brand name.
nsr-jamie
Jun 28 2014, 08:36 AM
Spent most of the day trying to install my Tangerine exhaust, not going very well and am having some serious clearence issues...hope to get it done tomorrow.
Socalandy
Jun 28 2014, 11:53 AM
Here's what I use and is designed for vinyl tops and headliners. Not cheap at $23 a can but six years later the sail vinyl and headliner on my old 72 is still holding. if you buy some make sure the can has stage 2 on it as there is another can the same color but not rated for heat and exterior.
hblyle
Jun 28 2014, 06:11 PM
Covered the passengers side door panel, fiberglass panel from 914Rubber!
Hank914
Jun 29 2014, 12:52 AM
Pulled the speedometer from my '72 and I'm going to let Palo Alto Speedometer replace the little plastic gear on the odometer. I looked at all the various posts from the DIY'ers and it does sound attractive to just pay $25 for the gear and maybe a few more for the bulbs. Everybody has written it up very well, it seems step by step easy enough. But I just don't have the time to do it myself. We will see how backed up they are on Monday. If it is too long a wait, I may just find the time. Mine is a daily driver, so the speedo is better than guessing the speed...."hmmm, 3000rpm in 5th, so I'm about 70-72mph. Stay under 3400!"
eyesright
Jun 29 2014, 07:42 AM
I got hood shocks from Camp914 and installed fronts on my '70 -6 conversion project.
I found that the shocks are pretty stout and the attachment at the spring anchor was bending in from the pressure. So....take apart....find some 5/8" scrap strap metal...overcome OCD impulse against using English measurements....drill holes for 10mm shaft on one end and 6mm one the other to line up with tangs on the spring anchor....grind and file....prime and paint....install with moderate effort and minimal foul language. Now the hood works and the spring anchors seem to hold. It will get a catch installed today too and hood emblem reinstalled....Holes drilled a little high by DAPO so what can I do...aaaaaannnddd....DONE! Engine goes in next.
Click to view attachmentClick to view attachment
anderssj
Jun 29 2014, 06:14 PM
Finally got around to installing the brake light strobe module (LSC-100A) for my high-mounted center brake light. Works.
Then drove it.
If interested, here's a link to the module:
http://www.superbrightleds.com/moreinfo/ca...obe-module/195/
bdstone914
Jun 29 2014, 06:52 PM
QUOTE(anderssj @ Jun 29 2014, 05:14 PM)
Then drove it.
http://www.superbrightleds.com/moreinfo/ca...obe-module/195/The specs say it is only rated for 15W. Sounds low for two brake light bulbs.
Mblizzard
Jun 29 2014, 07:18 PM
QUOTE(bdstone914 @ Jun 29 2014, 04:52 PM)
Then drove it.
If it was done like mine, it was used only for the center mounted LED light not the bulbs in the tail lights.
euro911
Jun 30 2014, 01:11 AM
QUOTE(t collins @ Jun 27 2014, 02:31 PM)
DRPHIL914
Jun 30 2014, 05:55 AM
I prepped the 914 this weekend for driving it on a more regular basis since the wife wrecked the jag we have not replaced yet, and last friday i sold my Boxster, i will be driving the 914 2 -3 days a week until the other car is replaced, kind of looking forward to that- one last thing left to do, re-bleed the brakes and get that pedal more firm-no leaks just have not been able to get all the air out of the lines since replacing all the lines hoses and calipers this past spring
Mblizzard
Jun 30 2014, 06:11 AM
QUOTE(Philip W. @ Jun 30 2014, 03:55 AM)
I struggled with that for a long time. Might have just be luck but a couple of times of bleeding both the top and bottom bleeder screws on the rear got the last of the air out of mine.
crash914
Jun 30 2014, 06:17 AM
Mr.242
Jun 30 2014, 07:18 AM
Had a nephew in for a family visit and he wanted a ride, was warming it up to go and the Seattle rain began to fall. So with no 'Rain Shields' I pulled it back in the garage. That nephew of mine just saved my car's life! I found a sheen of gas on that new rain.
Rain leak detected a gas leak. While it rained, I searched for the leak and found that only when running fuel to the carbs did gas pressure cause a leak at the distribution line to the carbs. DOH! Fire averted...
I believe I fixed the leak, so much moisture and gas odor so strong I couldn't be sure. So... While it rained, I installed the K&N Rain Shields so I can drive if ever caught by a sudden Seattle rain.
I ended up missing entry in the lone car show I enter every year. Oh well...at least I didn't catch my car on fire and lose it forever.
Jun 30 2014, 11:25 AM
anderssj
Jun 30 2014, 12:08 PM
QUOTE(Mblizzard @ Jun 29 2014, 09:18 PM)
Then drove it.
Yes, center-mounted light only; it's a LED unit from Volvo V-70 or something.
jamracing
Jun 30 2014, 05:25 PM
A friend of mine is a graphics designer and made me some cool magnets. I have about 10 of the Porsche logo magnets that I will be selling.
Mblizzard
Jun 30 2014, 05:58 PM
QUOTE(jamracing @ Jun 30 2014, 03:25 PM)
Pretty cool! How much?
jamracing
Jun 30 2014, 06:31 PM
I'm thinking $25 for a pair shipped.
poorsche914
Jul 1 2014, 07:40 PM
mskala
Jul 1 2014, 07:57 PM
Made a couple jam nuts for the gas pedal stop. Don't want that screw
turning unexpectedly
Mblizzard
Jul 1 2014, 07:59 PM
QUOTE(poorsche914 @ Jul 1 2014, 05:40 PM)
What size did you go with?
poorsche914
Jul 1 2014, 08:22 PM
QUOTE(Mblizzard @ Jul 1 2014, 09:59 PM)
205/50
euro911
Jul 1 2014, 10:17 PM
QUOTE(mskala @ Jul 1 2014, 05:57 PM)
Made a couple jam nuts for the gas pedal stop. Don't want that screw turning unexpectedly
3-D printer?
ClayPerrine
Jul 2 2014, 04:01 AM
QUOTE(jamracing @ Jun 30 2014, 06:25 PM)
Expect a Cease and Desist letter from Porsche to show up soon. They don't like it when you use their Trademark without permission.
dangrouche
Jul 4 2014, 06:27 PM
backflushed a handful of injectors; it really works and debris did flow out. built this rig after seeing some else on the board post a pic of his set up.
cary
Jul 5 2014, 12:32 AM
Disassembled my center console and reassembled it with next size larger screws.
Its finally fully intact.
Then I put disconnects in the wiring so it can be serviced without tearing it up.
euro911
Jul 5 2014, 12:35 AM
QUOTE(dangrouche @ Jul 4 2014, 05:27 PM)
Pretty cool idea
euro911
Jul 5 2014, 02:24 AM
QUOTE(ClayPerrine @ Jul 2 2014, 03:01 AM)
I'd better order some before the lock, then
jamracing
Jul 5 2014, 07:08 AM
QUOTE(euro911 @ Jul 5 2014, 03:24 AM)
I think an official cease and desist letter from Porsche would be a badge of honor worthy of framing. PM me if you want a set, a few people already have.
JoeSharp
Jul 5 2014, 07:11 AM
Moved her to her new home.
rmdinmd
Jul 5 2014, 08:14 AM
yesterday I installed the LED lights I got from spoke.
Click to view attachmentAnd installed another rubber window seal from 914 rubber.
Click to view attachmentthen I
and watched the fireworks.
Going to be working on the targa top next.
eyesright
Jul 5 2014, 08:18 AM
I turned this.....
Click to view attachmentInto this.....
Click to view attachmentMaybe turn the key in a couple of weeks?
kwfast
Jul 5 2014, 04:49 PM
installed a Tangerine firewall shift rod bearing upgrade....hey, I can find the gears now
Mblizzard
Jul 5 2014, 06:17 PM
QUOTE(kwfast @ Jul 5 2014, 02:49 PM)
Click to view attachmentDid you intentionally leave the cover off? That is going to be my next upgrade!
euro911
Jul 5 2014, 06:57 PM
QUOTE(Joe Sharp @ Jul 5 2014, 06:11 AM)
Where to?
Got pix?
We miss you out here on the West coast ...
kwfast
Jul 5 2014, 08:55 PM
QUOTE(Mblizzard @ Jul 5 2014, 08:17 PM)
no..rubber just pulled back for the picture
