Started out yesterday afternoon to bleed the rear brakes. Did calipers, rotors, MC, lines, etc months ago and pedal was still a little soft so figured it was time.
Turned into a serious case of 'while I was in here...'
Bled both rears, got some bubbles, pedal seemed a little harder.
Replaced brake pad retaining pins and springs with new ones.
Decided I would finally install the new muffler I got from Ben/mb911 almost 2 years ago.
Pulled the old one off, HE to muffler gaskets looked like they were leaking, so need to find new ones.
Check the transmission plugs to make sure they will come loose, and check the oil level. All good there.
While muffler was off, I noticed the heat shield looking pretty crusty. Don't think it has ever been off the car. Screws are in the rear trunk, but... It is full of '914 stuff' that I have been carting around for the past 30 years. Same with the frunk.
I had picked up an old cabinet that a neighbor was throwing out about 2 months ago. Three ft wide, with drawer and 2 sliding shelves. Thinking at the time it would be a good place for the 914 stuff. It of course was sitting behind the car...
So move things around in the garage, place the cabinet, and transfer stuff to it. Fewest things I've had in the 914 in a long time.
Click to view attachment Back to the heat shield. Three screws came out easily (two still covered in the putty); 2 needed a little coaxing, last one wasn't having it. Vise grips, rust dissolver, drill, nothing worked. Finally had to grind the head off. Shield came out, spent more time getting the remnant of the screw out of the speedclip.
Cleaned off the loose rust and painted it with rust preventative.
Staring at the open trunk lid, I noticed the spring latch also looking a little rough. Pulled it off, cleaned up some rust, took all apart and cleaned/lubed, painted the mounting plate.
Back under the car, thinking the rear trans mounting bolts haven't been touched in 30+ years and I may be dropping the engine/trans this winter/next spring, so maybe I should see if the bolts will loosen. Fortunately they did without too much effort. But now I'm looking at the rubber mounts... At least 35 yrs old, if not original. Time to pick up a set at the 914Rubber sale??
That's when I called it a day.
