The fan end seal started leaking really badly on Elwood coming home from the Porsche 70th celebration in Ft. Worth. You have to pull the motor to replace it, so I started gathering parts. Saturday we pulled the motor and trans and started stripping it down to the long block.
Betty was out in the garage helping. I asked her to take the transmission mounts off. She didn't need the wrenches. She just pulled them forward and unscrewed the bolts with her fingers.
I pulled the fan/alternator off the motor. The fan had 0 shims in it, and the alternator ground strap was broken. Once I got the fan assembly off, this fell out:
Click to view attachmentYea, those are corn kernels. I am not surprised, the car was an Iowa barn find.
Ran out of time on Saturday, and yesterday was taken up with running some errands, so I got back out there this morning. I pulled the intakes, and put corks in the ports. Then I removed the fan shroud.
Click to view attachmentMouse fur... lots of mouse fur. And more corn. So the rest of the morning has been cleaning out the mouse fur.
Luck was with me, I didn't find any mouse carcasses.
I pulled the transmission and the flywheel. I was already going to replace the flywheel seal, but my case of Dirk Wright's disease flared up. So now I have a new clutch kit for him. Good thing too. There are absolutely no plastic parts on the clutch arm. None. Nada. MIA. Vanished. Gone the way of the Dodo.
I am taking all the tin, the fan shroud, the fan, and the upper valve covers to be run through the ultrasonic cleaner at Zims. After they come back, I have to paint them.
All of the bolts and nuts are in the tumbler getting cleaned too.
I am hoping I can start re-assembly on Thursday.
