QUOTE(ClayPerrine @ Jun 15 2023, 10:26 AM)
QUOTE(Jamie @ Jun 15 2023, 09:17 AM)
QUOTE(ClayPerrine @ Jun 10 2023, 03:36 PM)
Today we took Elwood (the Factory Six) to Park Place Porsche in Dallas for the Porsche 75th anniversary celebration.
Click to view attachmentBetty and Elwood, both lookin' good!
Looks great.. runs like
Cylinder #5 is not firing. Changed the plug, and wire, no joy. Took the gas torch and fed acetylene into the #5 venturi on the car. The miss went away.
I think I have a blocked passage in the left carb. I have to pull the top after work today and see if I can clear it out.
Did I ever say how much I dislike carbs....
After you fix it again, which I am sure you will (clean)
Might I suggest you install a fuel shut off in prior to the carbs.
then when parked, shut off the fuel and let the carbs suck all the fuel out till the car dies.
Works really great on a 356, keeps the carbs from gumming up.
Starting does require a bit more cranking...but yah...
Matt, working with Mark at Exotech in Plaistow nh, just installed an easily reversible ITB solution with a dedicated brain onto his 914/6 race car.
when air cleaners are on....its hard to tell.
Starts and runs perfectly now, versus carbs...which don't always do that.
If you want to see it, I will find the thread he posted, I think its on the PP forum, possibly in the 911 engine forum...one of the threads on ITB.
I will follow suit, just wanted to see how easy and simple it was to tune.
they did tune it at a track, but now they know how to tune it
found it
http://forums.pelicanparts.com/911-engine-...sion-kit-2.htmlMatt Romanowski is the poster.
Rich
