QUOTE(ClayPerrine @ Oct 4 2023, 11:09 AM)
QUOTE(Shivers @ Oct 2 2023, 08:19 PM)
Click to view attachment And done. Moving on to the next step
Why didn't you just weld the splined end into the shift rod? The U-Joint will bend, and everything will still work great.
I took all the stock parts and laid them on the ground and marked where everything was from the factory
Beginning of the rods, end of the rods, curves of the rod. I then laid out the project parts on the drawings on the ground with the ujoint in place. To get the best angle on the ujoint and keep the rods in place, That was how I did it. I had no car with a sideshift bar and trans to fit to, so I had to keep everything in its place. As well as I could anyway. Plan is to make my shift console with a seperate rod and add a second ujoint, but it will be long enough to run it stock if I change my mind. That console shaft will not be cheap.
@DRPHIL914 Well, I'm at a point where if I can't make it, fix it or modify it to work, I will find a used one good enough to fix. I've had over 40 years to dream up stuff to do to this car. Saw my first mid-engine buggy long ago and the first thing I noticed was the linkage.
A true tail shift owner. lol
Thank goodness I have most of the parts to remedy that.
