Lawrence, Forrest and I dropped the 2.0L out of my '67 911, then hoisted it into Lawrence's truck.
The transaxle had no problems and doesn't leak anywhere, so I decided to remove the motor without the transaxle - actually went pretty well considering this was the first time I'd ever attempted this method. It was good having three people to do it though
However, we did run into some negative issues. We stripped the end splines on a triple square tool trying to remove two of the flywheel bolts
... I ground a 1/4" or so off the end of the tool while Forrest took a MAP Gas torch to the bolts - and we finally got 'em out
After they left, I tied the rear of the transaxle up with a ratchet strap and removed the floor jack. Used the tops of the shocks stems as the suspension points.
The TO bearing had more slop than I liked, so removed it and pulled a new one from stock. I need to do a little clean up in the bell housing and re-grease a few places next. The flywheel, clutch disc and pressure plate all looked good - need to order some new flywheel bolts and then I can slap this puppy on the replacement 2.0L motor.
As usual, forgot to take a camera to the shop
