drove to work today - since re-crimping the connectors of the d-jet injector harness grounds and strapping the harness so that it will be less likely to move or pull loose, its running really good, no miss, no mess, no fuss.
Well, now I need to look at why my idle is so rich but the running A/F is perfect part load and full load. and adjusting the ECU has no effect, so I guess the TPS is not set, I remember Rich saying that if the TPS is not set right then the idle adjustment on the ecu will not adjust - but I did put it in exactly the position that the picture he set says to, so any ideas?? -
also noticed a bit of a front vibration at the wheel at 65mph on way to work, balance perhaps?
I wonder if I lost weight off one of the wheels, they were inner weights- I didn't want to have any on outside of the new refurbished Fuchs I have on. Tires are 1 year old Bridgestone Potenza. Hm- always something...
