well lots in the past week, pulled the motor and trans, due to a leak- 2500 miles on rebuilt motor, just 1000 since resealing transmission and new rms last spring, yet here we are with a leak- what is it??? well let’s find out- it’s not the transmission that’s bone dry, it’s the RMS which was a VR from LN, 12mm upgrade from stock 10mm, and also i might have a deep from the plug at the end of the camshaft, not sure yet , but the galley plugs were dry. i have 2 pushrod tubes with a drip(also done last year) so we’ll take care of that, -
-checked the crank endplay ans shims to make sure, but we’re good to go @iankarr thanks for video and advice , refresher on doing this ans link for the meter. i have perfect shim thickness ans endplay that’s verified by multiple tests and almost ready for the flywheel to go back on. i installed an Ehrling RMS this time. SABO are not available due to problems with their manufacturing, molds
wearing out and not getting good seals anymore .
- should be back in the car by saturday but i am in process of gathering new FI system parts ans that might be in the car soon.
tin is getting cleaned up and new fuel lines and then get her back together. i can’t stand leaks!!! 2 year old dansk oil cooler has a crack so new one of those as well!
i really need a lift !!
