did a number of things this last week.
pulled the rt carb to add the adaptor for the combo oil pressure sender (light and PSI) and CHT sensor. then learned how important it is to make sure you have NO air leaks.
Thought I had a bunch of birds in there.
Click to view attachment oil pressure
Click to view attachment CHT
pulled and cleaned the plugs as they don't seem to be available locally. ordered 2 sets.
adjusted the timing the best I could figure, then took it for a drive and tweaked it until it didn't ping when getting it in 4th.
installed the center console, made a 5 gauge holder, (actually made 2 but didn't like the layout of the first one). also had to make the bottom as I didn't have one. Will have to remake as the "cup holder" I tried to put in just isn't right. Will eventually cover the pieces , this is just a test right now.
Click to view attachment I had taken a picture going down the road but it was just a little fuzzy.
I then drove it 650 miles from Baltimore, Md to Clarksville, Ga.
Found out that when going up the mountain I might have to drop all the way down to 3rd. But it did good.
Oil pressure ranged from 40 to 60 psi, oil temp 190 to 230 and CHT averaged about 340 and went up when climbing the "hills". I have the CHT set to start flashing at 370 and never allowed it to go past 390. Even then not for very long, that was when I figured out I might have to go all the way down to 3rd.
