A little update on the weekends work on Mike's (Warpigs) car.
Added lift rings to his engine for easier lifting too and from the table and engine stand.
I added an extension to the front one. I think I'll have them lazer cut on the next batch that Rothsport does.
Click to view attachmentRemoved the 1/2 shafts and ran the hubs thru the parts washer.
Mike's going to rebuild the half shafts during the week.
That's not water. Sprayed them down with WD40 to keep them from rusting instantly.
Click to view attachmentDid a temporary repair on Mike's Hell Hole. Car will get restored/rebuilt into a GT in couple years. Patched and treated with OSPHO after this shot. A couple holes starting in the wheelhouse wall, but I didn't touch them. Not in the scope of work on this project. They'll get a dab of seam sealer and the entire area will get sealed up with Eastwood HD Anti Rust.
Click to view attachmentPrimary Sunday project. Creating and installing relocated fuel pump harness. In the snorkel and lays with the harness and speedo cable.
Click to view attachmentNeed to determine point of entry into the tank cavity and solder on the OEM connector when the final length is determined.
