QUOTE(Moneypit @ May 12 2014, 12:59 PM)
QUOTE(bulitt @ May 12 2014, 02:04 PM)
QUOTE(Moneypit @ May 12 2014, 02:51 PM)
QUOTE(chads74 @ May 12 2014, 01:09 PM)
I have been hearing all about this plastidip, so I figured I would try it out. Since my paint looked like crap anyway I didn't have much to lose and I think it turned out pretty nice for my first experience with it.
Click to view attachmentWow! This seems like it would be a handy way to "mock" up a paint scheme to see how it might look on the car. Specifically, if you wanted to use it on your rockers, wheels, bumpers, or other bits to try out LE scheme variations.
I've personally been considering an LE scheme with Adriatic Blue instead of the Creamsicle scheme and no lettering. Obviously a lot of work between now and then, but keeping the car white means less repainting inside and keeping the original color. I really like the contrast of white Empi wheels with the white body instead of trim colored wheels, but since it isn't an LE I have room to fiddle with it. I've been undecided as well on whether to go with FG bumpers, or get the original ones rechromed.
Then take it to the carwash and watch the horror as your paint goes down the drain...
Lol. I thought guys have been using Plastidip on wheels for a good while now. I miss something? I like the 914 visualizer but it could use some more parts and stuff to be added, as well as some better source photos for the wheels and other bits.
It has been around for a while, but I am just hearing about it I guess. I have heard a lot of people doing there wheels are having problems cause of the heat produced, the dip will start to peel after a couple thousand miles.
The plastidip is a nice cheap alternative to spending thousands on paint when your not sure what color you want, and if you don't like it, simply peel it off. Although I am not sure how easy it will actually be to peel it, but I have heard that it easy as long as the plastidip was applied correctly(thick enough). Again with being applied correctly, I have seen people pressure wash their cars and not have it come off, but I am sure if the water hit a place where the plastidip had lifted, torn, etc it would peel right off. But in my opinion, for how cheap it is I'll take it, but overall I am very happy with how it turned out.
