Troubleshooting a too high idle which I think is related to the idle control valve or logic.
Whose idea was it to put a water cooled motor in the car?
Current problems related to the addition of water....
The motor spit up a bunch of coolant out of the fill tank after sitting idle for about 5 minutes.
Radiator cold to the touch as are the hoses right at the radiator.
I believe it is operator error. I removed the thermostat bypass hose (used to feed the heater core in stock apps) so no water is flowing like it should unless thermostat is open. Done for the day and will have to look at it again tomorrow.
Roger,
That Nissan powered 914 looks great!
