QUOTE(Phil Plummer @ Aug 23 2014, 12:04 PM)
Hi : anybody out there know how to lower the front end? an inch or 2 would be great
It's not too tough of a job. Raise the front of the car enough to get to the front cross member and jack stand it.
There are two adjusting screws where the control arms pivot on each side of the cross member. You don't need to turn them very much to achieve a 1" drop. 2" might be too much, depending on the current height of your car now.
Sitting level with no driver or passenger is probably the best height to adjust to, so it doesn't drop much further when loaded. You may need to realign the front suspension after changing it ... almost a guarantee if you go 2".
After adjusting, drop the car back down and drive it around the block, then check for settled drop and any rubbing issues, also check your level from side-to-side. Measure the height from ground to the bottom of your rocker sills or to the center of the wheel well openings.
Repeat the procedure until you're satisfied. Again, you may want to have the alignment checked and adjusted by a pro shop.
Check the Pelican forum (tech article section), I think there's a step-by-step procedure there (with pictures).
Another Question is there a site out there that sells some clips or fasteners to keep my throttle cable from burning on exhaust ? and fasten up other cables ? an after market fireproof throttle cable from Patrick motor sports was in stalled after I put in the 911 sc engine I kept the fuel injection.
if anybody knows any of this pls let me know
Ty-Wrap loosely to the other cables, or fabricate a custom bracket?
